Amp Help
Old Jan 1, 2007 | 07:44 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Amp Help
Ok lets say I have (2) 4 ohm subs....
What should I be looking for out of an amp if its mono? Like 1600W x 1 RMS @ 1 ohm?
What about a 2 channel?
Old Jan 1, 2007 | 08:00 PM
hillbillyinOhio's Avatar
Default RE: Amp Help
with 2 4 ohm subs you are gona need an amp that puts out max power at 2 ohms. some two channel amps do put out max power at 2 ohms bridged.
Old Jan 1, 2007 | 08:07 PM
wolv2401's Avatar
wolv2401 is an unknown quantity at this point
I know this might sound dumb, but you also have to take into account the power of the subs you are trying to amplify. If you only have 2 500 watt RMS subs, don't try running 1000x2 amp through them. Overpowering can be just as bad as underpowering the subs.
Take care.
Old Jan 1, 2007 | 11:55 PM
Well I obviously know not to overpower the subs, but underpower? I have never heard of that.
Old Jan 2, 2007 | 12:06 AM
yes, you can hurt subs by underpowering them. if the signal is clipped, from cranking the gain on a smaller sub to compenstate, it will eventually fry the sub.
Old Jan 2, 2007 | 12:15 AM
Blazin_Jason's Avatar
Maybe to help and clear that up without causing too much confusion. Underpowering a sub will NOT blow/wreck/destroy a sub. Like hillbilly said if the gain is cranked and the amp is sending a clipped signal to the speakers that can cause damage. The lack of power is not what is damaging, it is the clipped signal. Usually caused because they want it louder and crank all the bass boost/gains and settings on the head unit.
Old Jan 2, 2007 | 12:22 AM
Ohh so seeting like "sub" on my head unit to 10 (max) would damage my subs? I dont really understand what gain, and clipped signal is.
Old Jan 2, 2007 | 12:48 AM
Read this (gain is listed, just have to scroll down)
CLICK ME!!, entire site,and you will learn a huge amount. I still check in on the site every now and then just to refresh things, and help me explain them better to people who ask.
JohnBarJB
Sep 28, 2020 07:34 PM
dj00140
Apr 13, 2011 10:40 AM
dougs10
Dec 14, 2010 03:24 PM
bfsmith72549
Nov 1, 2010 05:44 PM
RCarp48
Apr 2, 2007 07:19 PM
