amp hook up
Old Mar 28, 2007 | 05:21 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
Default amp hook up
might be gettin a deal on a set of 12's but i got a question how do yall hook up the amp to the battery? mine is the side terminal and there rubber so there no way of sliding a wire connecter over the battery post. so i was wonder how yall did urs?
Old Mar 28, 2007 | 05:24 PM
hillbillyinOhio's Avatar
Default RE: amp hook up
prefect excuse to upgrade to a new battery. I have side posts and top posts.
Old Mar 28, 2007 | 05:27 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
i had one car like that. i used a dremel and a sanding drum to sand back just enough rubber so that my terminal ring would fit on there, it still sealed great, and it worked perfictly for years.
Old Mar 28, 2007 | 06:31 PM
nai0013's Avatar
nai0013 is an unknown quantity at this point
I did similar to Zygoat on mine until I purchased my optima. On most of my old cars a cut the factory wiring and used a battery terminal like this Ebay Link
Do you need detailed instructions on how to do your ENTIRE amp hook up?
fixed long link - hillbilly
Old Mar 28, 2007 | 07:01 PM
viper4559's Avatar
viper4559 is an unknown quantity at this point
You might look to see if you have a power outpost anywhere in the engine compartment. On my old '84 there was a power post right above the engine that had my amp, car alarm, driving/fog lights and a couple other factory things hooked up to it. On my new 2000 I am pretty sure there is one almost in the same spot, I haven't come close to switching subs over yet so I just took a glance for it.
Old Mar 28, 2007 | 11:45 PM
mudsliner's Avatar
brand new battery so taht out and im not real sure what yall are talkin botu cut thje rubber. and no i can get teh rest of it hooked up ive just never hooked one up with side terminals.
Old Mar 28, 2007 | 11:52 PM
there is a rubber seal/insulation around the terminal(wire end) if you cut that bck you can fit a ring terminal in there. you might have to get a GM post extender. Post extender on Ebay
Old Mar 29, 2007 | 01:25 AM
jagblazer01's Avatar
i switched over to a yellow top so i have top and side posts. but you can always to the post extenders like hillbilly said
Old Mar 29, 2007 | 10:33 PM
mudsliner's Avatar
got it figured out gonna have a buddy help me. he did it in his satern so it the same deal with my blazer. but thanks for the help.
blazenblazer
Mar 7, 2010 09:05 PM
stealth1998
Nov 11, 2009 02:08 PM
midnightryder
Aug 8, 2009 12:17 AM
madeforliving
Feb 17, 2008 11:07 AM
blazer123456789
Dec 28, 2006 12:31 AM
