Putting corner strobes in my blazer
Old Mar 28, 2007 | 11:55 AM
lafd55's Avatar
lafd55 is an unknown quantity at this point
Default Putting corner strobes in my blazer
does anyone have corner strobes in front and back of their blazer? if so can u tell me how u wired them from the taillights and what is the best way to wire(i.e. underbody, interior panels, etc.)
Old Mar 28, 2007 | 05:24 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
Default RE: Putting corner strobes in my blazer
i have never done it but if you run them inside the vehicle they are better protected, it is usualy harder tho. you can always put them in a wiring harness under the car. if it were me i would run them inside the car, thats what they did from the factory.
Old Mar 30, 2007 | 09:04 PM
lafd55's Avatar
i would but very little room, but im already set at running the wires through chassis. still need help with power supply(where to put it, if i need anymore wires), i have a wiring diagram but would need further instruction(not so good with wires). i am 18 and will bring it into shop teacher at school, but still need info on installing from you guys.
Old Mar 30, 2007 | 09:11 PM
Zygoat's Avatar
i dont know if you can upload the wiring diagram or not but thats the only way i could help you on how to hook it up. if the powersupply is in its own protective case i would recomend mounting it in the engine bay some where close to the battery if possible, basicly anywhere it will fit and be away from anything hot or that moves.
ProSniper
Jun 21, 2014 08:01 PM
Cmkubbs01
Feb 9, 2014 04:42 PM
matthew.chapman1
Aug 16, 2009 09:01 PM
BlazinOn20s
Aug 3, 2006 08:00 PM
