amp placement
what i do is i screw them to the box, then i turn on their cloaking mechanism...lol. nah, my amps are too big to hide. well, my merlin is screwed to the back of my box, which is up against the rear seats, so u can only see the top of the amp. my orion however, is out in the open. just get tinted windows (if you dont already have them) and an alarm.
actually mounting the amps on the box is not a good idea.. worst case scenerio, u get broken into, theives take easiest thing, the box.. and if theyr lucky, tha amp is screwd to the box... i used to do my installs that way.. so anywhere else besides the box would be better
If you really want a cool mounting place in a blazer. If you have your spare tire in the back of your truck. Take the tire off and mount the Amp on the spare tire rack. Im currently trying to do that. Doing that also will help disapate the heat of the amp.
actually mounting the amps on the box is not a good idea.. worst case scenerio, u get broken into, thieves take easiest thing, the box.. and if they're lucky, the amp is screwed to the box... i used to do my installs that way.. so anywhere else besides the box would be better
ORIGINAL: XBlazer01
How about a place where the amp could be mounted that would be out of sight? More importantly, a place that would not be in the way should you need to actually use the extra cargo space? Thats my biggest problem.
