amp placement
Old Feb 22, 2006 | 02:02 AM
  #21
audiophyl's Avatar
audiophyl is an unknown quantity at this point
Default RE: amp placement
Thank you for making the corrections...it was bothering me as well!!!
Old Feb 22, 2006 | 01:37 PM
  #22
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
I was looking around in my 03 two door for just such a place yesterday. The best i came up with was behind the drivers seat. I would put one there, and build a little wooden box that i would cover in black carpet (like my truck) and i could just put that over it if i needed to, but i would leave it open unless i park somewhere shady, or i have somebody ride back there. The only thing is, i don't think you would be able to fold the seat down. This would be a hell of a spot for a number of reasons, the center console is right there, so i could probably run the wires right into it, and there are a few seatbelt mounts right there, in front and back of it making for a good ground spot.
Old Feb 22, 2006 | 04:45 PM
  #23
FatRyan's Avatar
FatRyan is an unknown quantity at this point
ORIGINAL: Canadian88
seat belt bolts are horrible grounds
Old Feb 22, 2006 | 11:28 PM
  #24
Canadian88's Avatar
I mis-spoke, i meant to say seat mounts. Are those any better?
Old Feb 23, 2006 | 09:42 PM
  #25
audiophyl's Avatar
I would make your own ground whenever possible, as opposed to using an existing bolt. Personally, I like to drill a hole into the metal, grind off the metal on both sides and insert a bolt through the metal of the vehicle. This way, you get a solid ground and a good place to ground all of your electronics, such as the headunit, amps, processors, etc.. to help eliminate the possibility of a ground loop. Just be sure that you protect the bolt under the vehicle as you don't want it to rust.
Hope this helps!!!
96jimmyslt4x4
Feb 24, 2011 07:15 AM
thrash902
Jan 28, 2010 06:58 PM
El_Beautor
Feb 26, 2008 10:33 PM
982DRBlack
Apr 16, 2007 11:11 PM
jerickso
Apr 20, 2006 11:05 PM
