Amp power wire location route?
Old Oct 18, 2010 | 04:09 PM
Blaze the S10 4x4 Blazer's Avatar
Blaze the S10 4x4 Blazer is on a distinguished road
Default Amp power wire location route?
Ok I have a 1990 s10 2dr 4wd blazer and I would like to know if anyone has any ideas as to how I can run my amp power wire Without drilling into the fire wall would be great, but will do if i have to.
Old Oct 18, 2010 | 04:10 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
you didnt even bother to search did you?
Old Oct 19, 2010 | 04:06 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Passenger side firewall just drill to the right side of where the harness wires go through make sure to use a grommet before you fed the wire through.
Old Oct 20, 2010 | 09:50 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
I ran mine along the frame rail from the engine compartment. i put it in split loom and zip tied it along the way. Very easy install. I then drilled into the area under the rear seat and installed a grommet. Pulled it through and 15 minutes later i was done. It is safe and out of the way.
96jimmyslt4x4
Apr 15, 2011 06:45 PM
streblo
Apr 2, 2011 03:43 PM
ExplicitYourSelf
Jun 24, 2010 07:28 PM
TAZ454
Feb 25, 2010 09:04 AM
2000CaliBlazerMan
Aug 9, 2007 03:38 PM
