amping door speakers
Old Dec 16, 2006 | 02:10 PM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
Default amping door speakers
well im planning on amping my door speakers but have never done it before. Ive hooked up subs several times so i know about hooking up power, ground, remote, rca's. The only question I have is how do you hook up the speakers?? Do you have to run new speaker wire from the amp to the speakers or is there a way you can use the factory wiring behind the head unit?
Old Dec 16, 2006 | 02:20 PM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default RE: amping door speakers
the way i always did it was run the wire through the little boot. the black part where most of the wires run from the door to the dash/fuse box. then i took up my carpet and ran them under that. that's a rather hard way to go, but it worked for me. you can take up the door sills and run them under that if you like.
Old Dec 16, 2006 | 02:56 PM
blazinloud's Avatar
i would replace the crappy factory wiring, might as well while its all apart......
Old Dec 16, 2006 | 03:17 PM
hillbillyinOhio's Avatar
the cheater way is to pull out cd player, hook front speakers up to the rear speaker wire. ditch the front wire. just cap it off. then in the back, extend the rear wires to reach the amp, and run new wire for the actual rear speakers.
That being said, i would just rewire the whole setup.
Old Dec 16, 2006 | 03:37 PM
kaps's Avatar
kaps is an unknown quantity at this point
Not to go offtopic, but where do you plan on hiding the amp? I dont think there is enough room under the seats and didnt want to wire it to the back of the truck then run wire back up to connect to the speakers. Going to rip apart my dash later to see if there is anyroom there, but the amp I have is pretty big, 11" sqaure and is about 10lbs.
Old Dec 16, 2006 | 04:33 PM
jagblazer01's Avatar
will you be using factory speakers or a new set of components?
Old Dec 16, 2006 | 11:50 PM
blazinloud's Avatar
you want to put the amp IN the dash? I dont think thats such a good idea seeing as how an amp gets hot and needs ventilation. wouldnt wanna melt any wiring in there.......if you have a 2nd gen there are 2 extra glove box's in the rear seat......I've been trying to find an amp small enough to fit in there......
Old Dec 17, 2006 | 01:28 AM
exactly. thery'es not one. i always put my amps in the back next to the amps to my subs, and ran them from there. buuut, that's me. i do everything the hard way.
Old Dec 17, 2006 | 02:03 PM
blazinloud's Avatar
the hifonics warrior eagle looks like it might be the smallest.......the nakamichi is pretty tiny too, but more cash.......
Old Dec 17, 2006 | 02:29 PM
http://www.woofersetc.com/index.cfm?...roduct_ID=3978
this one would fit. took one out ant put it in there.
http://www.woofersetc.com/index.cfm?...roduct_ID=3983
this one fit as well.
