amping door speakers
Old Dec 17, 2006 | 02:39 PM
blazinloud's Avatar
Default RE: amping door speakers
check this out, smaller than the mtx, and its a 4 channel
http://www.onlinecarstereo.com/CarAu...roductID=13987
only 7.6"s wide
Old Dec 17, 2006 | 03:14 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
I may just go be going off on a limb here. But does the 4x4 2dr have those little compartments in the back passenger seat area like the Xtreme does? If so u could try putting the amp in there if ur dead set on hiding. (this may not be the reason. im to lazy to read) Also it MIGHT fit behind the glovebox (drop it down)
Old Dec 17, 2006 | 04:10 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
yea the 2drs have those little glaoveboxs in the back by the seat
Old Dec 17, 2006 | 06:46 PM
blazinloud's Avatar
ORIGINAL: XBlazer01
yep, exactly what I suggested, that would be a pimp spot, reduces the length of the wiring, cheaper, and a stronger signal
Old Dec 19, 2006 | 08:49 PM
kornphlake's Avatar
kornphlake is an unknown quantity at this point
I put my amp right on the transmission tunnel pushed up as close to the firewall as I could. I'vebeen planning on building a small box with a couple of fans to cover it up but haven't had the time. I've got a 4dr with the 40/60 split bench up front, you might have something else going on so mounting in the front might not be an option. Unfortunately there really isn't a good place in these trucks to mount an amp, there just isn't much space under the seats and if you need the cargo space at all, there's nowhere in the rear.
Old Dec 20, 2006 | 12:39 AM
blazinloud's Avatar
mounting em in the tailgate would be pretty narley
JRob238
Jan 1, 2010 07:15 PM
chevy8jr
Mar 12, 2006 11:22 PM
blazerscooby
Mar 9, 2006 03:24 PM
Canadian88
Feb 23, 2006 12:55 AM
Gunner Woody
Feb 8, 2006 11:22 PM
