Audiobahn A8001DT is this a good amp?
http://www.techronics.com/index.cfm?...roduct_ID=1430 $294 on amazon btw but is the class D circuit really all that better? I already have 2 10" dual voice coil 4 ohm impedence rated at 1000w max a piece, I will hook it up as a 1 ohm load 800w out of this amp http://rockfordfosgate.com/rftech/wo...p;woofer_imp=4 This would be a good amp to get right?
audiobahn is a cheap flea market brand that is only concerned about the appearance of their product. The amps are completely over-rated meaning that they will never produce their rated power unless they get struck by lightning.
the brand new Kicker WX10000.110kW WARHORSE should be good enough. its at 2ohm though. and, unfortunately, it requires 2 HO alts and kicker recommends8 800CCA batteries for optimal performance
lol
lol
http://www.techronics.com/index.cfm?...roduct_ID=3360 what about this amp? or this one http://www.techronics.com/index.cfm?...roduct_ID=7617
that kicker sx will destroy the pioneer and the audiocrap amps.
but you can still get a better deal than that.....
check out www.onlinecarstereo.com
http://www.onlinecarstereo.com/CarAu...roductID=16368
^^^cheap power, slightly over rated. probably closer to 1400rms
http://www.onlinecarstereo.com/CarAu...roductID=15528
more power^^^ and cheaper than the kicker sx
