big 3 on a 2000 chevy blazer
Old Sep 5, 2009 | 06:08 PM
rkilgore's Avatar
rkilgore is an unknown quantity at this point
Default big 3 on a 2000 chevy blazer
I would really appreciate any advice on this,I have a 2000 chevy blazer,I was wanting to do the big 3 upgrade for future use and i do have a after market system,Im using 4 gauge wire for my amps,I was thinking of using 2 gauge for the big 3 upgrade,Im not using alot of power from my 2 amps...My question is,I looked under the hood and on the positive side,I see 3 wires,One is going from battery to alt and the other 2 look like they might be going to a fuse block under the battery trey...Will i be able just to add the 2 gauge from the battery to atl and just still leave the OEM wires hook up like they were without taking them off?Will i still need to fuse it?Can i leave the OEM grounds still hooked up and just add the 2 gauge ground to them?I was reading where you can do that...I was not sure?Thanks!!
Old Sep 5, 2009 | 09:18 PM
rriddle3's Avatar
You can start by checking out this thread to see if it helps you, plus use the 'search' function for 'upgrade big 3' to see more threads.
Old Sep 19, 2009 | 12:45 AM
pmpnu2's Avatar
pmpnu2 is on a distinguished road
there is an excellent thread on www.stevemeadedesigns.com on doing the big 3. it has pictures and is explained in detail. you may want to check that out. just go to the forum, then scroll down to the alt,battery thread and its stickied at the top. very easy to find. hope that helps...also i can post pics of mine if you need me to, just let me know...
Old Sep 21, 2009 | 01:38 AM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
its about the best mod u can do if u have a yellow top or ho alt
ChevyMane808
Apr 5, 2013 10:51 AM
chris015
Dec 27, 2011 09:51 AM
southtexaswildfire
Dec 14, 2009 08:29 AM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
