the big 3
Old Sep 25, 2006 | 04:35 AM
chvycmaroz28's Avatar
chvycmaroz28 is an unknown quantity at this point
Default the big 3
i have a 98 blazer with the 4.3 in it and was wondering if somone cud walk me through on how to do it and where everything is gunna b on my blazer..ive seen post on how to do it on another site but i need somone to do into more detail....also is it worth it...i have a yellow top under the hood now and a 3 farad cap...
Old Sep 25, 2006 | 10:19 AM
jagblazer01's Avatar
Default RE: the big 3
check it out...everything you need to know
https://blazerforum.com/m_28516/tm.htm
Old Sep 25, 2006 | 04:03 PM
so all im doin is incleasing all 3 of those wires sizers basically right?
Old Sep 25, 2006 | 04:10 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
yep up the gauge wire to basically give the electrical system more "breathing room"
Old Sep 26, 2006 | 01:47 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
the question is Jon, how big to go? Im planning on using 4 gauge for mine. however, would there be a good reason to goto 0 or something?
Old Sep 26, 2006 | 02:41 PM
XBlazer01's Avatar
from the setup you posted that your going with. I'd do 0 gauge josh.
I have to find the gauge chart i found last week. but im pretty sure your gonna use 0 josh (to be safe)
EDIT Here's the chart
Old Sep 27, 2006 | 10:52 AM
thanks Jon, that helps a lot more than you know. from the plan im using, i will need 2 rolls of 0 gauge wire then.
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
sunpowered
Aug 17, 2005 11:30 PM
m00nwater
Mar 31, 2005 09:36 PM
78blazer
Oct 15, 2004 11:59 PM
