BOBDITTS official build thread
Old Nov 10, 2007 | 11:12 AM
  #91
hillbillyinOhio's Avatar
Default RE: BOBDITTS official build thread
so, locks all good???
Old Nov 10, 2007 | 12:42 PM
  #92
bobditts's Avatar
bobditts is an unknown quantity at this point
yep, thanks for the help on that. They didnt work at first but I checked the relays with a DMM and they werent getting power. I checked the fuse and it was obliterated. Must have happened when the wires burned up when I had it wired for 5 wire reverse polarity.
Old Nov 11, 2007 | 04:56 PM
  #93
Blazin_Jason's Avatar
Hey got a question. When you wired up the door lock relays, did you just wire as per the 5 wire 12+ diagram on the12volt.com in the drivers side kick only? Basically will the relays in the drivers side do both locks?
Old Nov 11, 2007 | 05:39 PM
  #94
yes they will. can you unlock your pass door from the drivers door?? Then yes!
Old Nov 11, 2007 | 06:35 PM
  #95
bobditts's Avatar
ORIGINAL: hillbillyinOhio
exactly what he said. In fact, I was able to stuff the alarm brain and all the relays into the panel behind the kick after making all the connections.
Old Nov 11, 2007 | 06:46 PM
  #96
Yeah I can unlock from there. Obviously it has 2 seperate switches one for each door. Just wanted to make sure that wiring it up like that is correct. Got lots of wiring to do tomorrow. :S
edit: Stupid how if you want full access behind the kick that the ebrake peddle needs to be removed. So did you have the wires come out of the grommet to goes to the truck? or did you just have them come out behind the access panel to the kick?
P.S. I hate unwrapping old electrical tape!
Old Nov 11, 2007 | 07:39 PM
  #97
get them wher they come through the door boot.
Old Nov 11, 2007 | 07:51 PM
  #98
bobditts's Avatar
ORIGINAL: Blazin_Jason
I didnt have to remove the e-brake pedal in my 1st gen. I had to remove the release handle but not the pedal. I only have 1 wire going into the engine bay for my alarm - the wire for the siren. I drilled a hole to the right of the master cylinder (if you are looking at it) and ran the wire to behind the kick.
Old Nov 11, 2007 | 08:08 PM
  #99
Hows this look? The blue wire is going to go to the motor/away from the door. Red wire to the swtich/door. White wire unlock. Black wire lock. The yellow wire to a fused 12 volt. Sound right?
Old Nov 11, 2007 | 09:21 PM
  #100
why are the blues and the red tied in together?? they are going to different wires each??
