Bolting Box Down????
you could use something stronger than pipe strap. I made 4 small "angle irons" and screwed two of them to the rear and one on each side. It'll make it harder for a would be thief to just walk away with your stuff.
ORIGINAL: audiophyl
Mount the sub box to the rear deck where the tie downs are located. Just remove the tie downs and install a bolt through the bottom of the box through the existing holes in the floor.
Good luck to ya!!!
Good luck to ya!!!
ORIGINAL: 4lowlife
Yep.
Good idea using the existing holes!
Yep.
