Bypass lights?
Old Apr 14, 2007 | 12:56 AM
viper4559's Avatar
viper4559 is an unknown quantity at this point
Default Bypass lights?
Does anyone know of a way to bypass the whole light sensors to allow the driver the ability to manually turn his lights to an "off" position somehow. Or wiring up a way that I can flip a switch to turn them off?
Old Apr 14, 2007 | 01:17 AM
hillbillyinOhio's Avatar
Default RE: Bypass lights?
this will help you in your quest!
click me!
Seems like i always pop up when you got a question bro.
Old Apr 14, 2007 | 12:26 PM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
do you have a bypass light for your interior lights? i found on mine that if you leave the light switch off and hit the bypass button rapidly like 2 or 4 times then the lights will shut off and you have control weather or not you want the lights on
Old Apr 14, 2007 | 03:14 PM
viper4559's Avatar
Hillbilly your just made to be my buddy! lol. Thanks for the link bro.
eshballa: thanks for the info dude!
I don't care about disabiling them all the time, its just sometimes I want to be able to turn them off (when we, we being teenagers, are doing stupid stuff with other friends vehicles). So if pushing it 3 times works then great!
Thanks to both of you I am content and happy.
Old Apr 14, 2007 | 04:23 PM
hockeykid15's Avatar
hockeykid15 is an unknown quantity at this point
hillbilly will that same ifo from your link work for my 97?
Old Apr 14, 2007 | 04:51 PM
Hockey, on your 97,(same as mine) if you take out, fuse 15, i think, its labeled DRL) it will disable the running lights
Old Apr 15, 2007 | 04:47 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
you can also engage your e-brake one click to turn them off, dont think i would ride like that all the time though, i just use the bypss switch when i want to turn mine off
Old Apr 20, 2007 | 06:03 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
All you need to do is pull the RF stereo speaker grille, unplug the electric eye sensor and insert a resistor into the connector. Then the light sensor thinks it's always daylight and you can run your headlights manually. I don't remember the resistance but a bit of searching online and you'll find it. Probably something like 20K ohms. The resistors are under a buck at Radio Shack.
Also, if you study the wiring diagrams you can pull the DRL relay under the hood and jumper across two contacts it leaves open to maintain full headlight functionality. I did this for a while, but then decided I was probably safer with the DRLs than without them, so I pulled the jumper out and re-installed the relay.
jhuseman
17
Jan 19, 2008 09:07 PM
Arvan
Jun 28, 2007 05:59 PM
BlznAnt
May 8, 2007 07:25 PM
94 blazer
Engine & Internal
Dec 19, 2005 12:50 PM
