Component systems
Old Nov 16, 2008 | 06:07 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Component systems
My right front speajer is blown, i thought about replacing just that one but i figured i would upgrade the front speakers. A couple of questions, for the tweeters do i just take out the old ones soder the new ones then there good to go? do i need to run better wires? Or do i just hook the new speakers to the old wires and im good?
http://www.bestbuy.com/site/olspage....=1199494646675
Was thinkin i would get these. I was also concidering just having them install for 40 bucks more. I know this has been covered just have some questions. Any help greatly appreciated.
Old Nov 16, 2008 | 06:15 PM
jagblazer01's Avatar
Default RE: Component systems
are you amping the speakers?? if not just connect them to the old wiring
Old Nov 16, 2008 | 06:21 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
if you run those non-amp'd they wont sound much better than the stock.
you can connect them to the stock wiring though.
Old Nov 16, 2008 | 07:48 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
typically there is a stock crossover soldered to the stock tweeter. If you replace any of the stock speakers, you have to use the crossover that is provided with your component set that you buy.
Old Nov 16, 2008 | 08:07 PM
is the crossover hard to replace? i will eventually want to amp them just not at the moment
Old Nov 16, 2008 | 11:57 PM
01vortec's Avatar
ORIGINAL: bobditts
i think the component set he posted is just like the stock ones, no external crossover included. If he buys a set with a external crossover then he'd have to be worried
Old Nov 17, 2008 | 01:46 AM
in4lo's Avatar
in4lo is an unknown quantity at this point
The crossover (which is just a capacitor on the stock set and the ones you're wanting to replace the stock set with) is on the connection terminals on the woofer on the Alpines. You'll have to run wire from the woofers to the tweeters, wherever you locate them. Of course, you can chop the wires off the stock tweeter and figure out a way to mount the aftermarket tweeters to the 4x6 plates that the stock tweeters are in.
Sturg
Jan 7, 2010 11:49 AM
viper4559
Dec 17, 2009 08:01 PM
strongboy2005
Engine & Internal
Feb 9, 2006 06:12 PM
the_mind
Oct 24, 2005 09:45 PM
einstein2nd
Headers, Intake, & Exhaust
Oct 18, 2004 11:33 PM
