Considering a sub for the blazer.
I've been toying with the idea of installing a sub in the blazer but I have a couple of concerns about it. First of all I have the steering wheel controls for my stock system and they are something I do not want to lose. I also don't want to sacrafice to much trunk space as I frequently fold down the seats and hall things like ski's snowboards luggage e.t.c. I would like to know if there is a system that would allow an aftermarket deck to be controlled by the steering wheel controls. Also I would like to hear peoples suggestions for optimizing the trunk space.
Thanks,
Nate
Thanks,
Nate
One ten or twelve is all you need to fill the lows... anything more will sound silly and take up WAY too much space. As for the sterring wheel controls, there are adapters all over the place that will allow use of the controls with an aftermarket HU. A good place to start with A/V is crutchfield. Good luck
ik theres some decks that have the option to be wired to ur steering wheel controls thru the factory harness but i'm not sure which ones. and a 10" or 12" sub will do u fine and not take up much space. plus u can leave extra wire so that u have the freedom of moving it around. i have my 2 12"s in the back and the spare on the inside side and i have about a 1/4 of the space left for other stuff. i did leave enough wire so i can fold down the seats and move the subs forwards or all the way back.
For the steering wheel controls, the units from pac-audio are the best. Check when looking into decks if they have a wired remote control lead, some do. if they do, look into the adaptor that is specific to that brand.
Not too bad to hookup, if you do the universal, its a PITA. Let me know if you need help on this. Ive done a bunch of them, and added controls to cars without as well.
Here's some options for retaining your factory controls:
http://www.crutchfield.com/cgi-bin/p...steering+wheel
As far as trunk space, I had a single 10 in a sealed box and it took up very little space. The two 15's I have now on the other hand...
sundown is coming out with a nice 8" driver that did like a 140 on a proto 2000d@4ohms
presale price is $48 each i belive
and after MSRP will be under $100
I should mention the 140ish was done in a 4th order bandpass....im not sure what the vehicle was.
I just intalled my new infinity kappa 12, and let me tell you that it is one of the most musical subs i have ever heard. I had high expectations, but DAMN, this sub is great. It's in only ~1 cube, and running off 300w. Its not a loud sub, but if you actually like to listen to music it is on the same level as an Image dynamics sub (maybe better).
first for the steering wheel controls....everything is in the factory harness so go to advance auto parts or autozone and pick up a wiring harness for the radio if u plan to change it...if u keep the factory radio they make a box with RCAs u have to splice into the factory wires...its like $15-$20 for that but u wont get a good quality out of it...second...doesnt matter the size of the subs...its the watts and ohms...and what u plan on having for sound...if u want a nice clean sound 2 10"s or 1 12" in bandpass boxes...or u can do 2 12"s for a way better sound...some brands are Memphis, MA Audio, JL Audio, JBL, and INIFITY...those are all GREAT subs....so whatever u choose make sure they tune it the right way or else ull be dissapointed
