convert Radio wiring
Old Jan 21, 2021 | 05:40 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Default convert Radio wiring
Hello everybody
I have question about the old style jimmy harness if it can be convert to the newer type which is come in Blazer/Jimmy 04-05 that come with double din.
My old style harness and the Radio
The newer version harness and Radio
Old Jan 21, 2021 | 06:43 AM
Anything is possible. I made an adapter to convert the radio plug in my wife's Hyundai Elantra to the same plug on my 04 Blazer, so I can hot swap radios if I ever want to, plus getting aftermarket radio adapters is a lot easier for the Blazer's generic GM plug than the Elantra...
With the newer style, you really only need the larger plug. I believe the smaller one is for systems with Bose audio, which incorporates a stand alone amp and all, so I wouldn't even try to get into that...
But all you would need is the pinouts and a couple plugs to just make a adapter harness. I certainly wouldn't go hacking up the wiring in the dash just to change the plug...
Old Jan 21, 2021 | 09:46 AM
Post
Do you know where can I find male connector for the old style harness? So, I will be able to use the old harness and the new one without touching the original factory wires.
Old Jan 21, 2021 | 09:52 AM
El_Beautor's Avatar
It's important to note that the newer style radio you show are VIN coded to the BCM. They have to be program matched to the BCM by a GM Tech tool. You can't just plug one in and have it work. I'm not 100% positive, but I doubt the older style BCM can be programmed to use the newer style radio if that's what you're trying to do.
I think your project might be a lot more involved and difficult than just changing over the wiring harness and plugging in the new radio.
Old Jan 21, 2021 | 10:29 AM
No, I already find a method to match the VIN coded using eeprom programmer
Old Feb 2, 2021 | 02:07 AM
Anyone have the wiring diagram of Single din and Double din wiring diagram ?
thank you
Old Feb 7, 2021 | 12:59 PM
LesMyer's Avatar
thank you
here you go
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 8, 2021 | 06:13 AM
Originally Posted by LesMyer
here you go
Thank you very much finally I got it. But I have a question about the wiring harness both manual show 1999 and 2004 have same connector 12110088 but they are not ?
PhantomDiesel
Apr 13, 2020 02:08 AM
blazen_red_4x4
Oct 28, 2017 09:27 PM
serrasalmus
Mar 4, 2012 06:32 PM
_HeC_
Mar 4, 2012 02:56 PM
denver jimmy
Oct 4, 2010 12:56 AM
