Dashlights not working 2004 S-10 Blazer
Old Sep 7, 2009 | 11:02 AM
marctre's Avatar
marctre is on a distinguished road
Default Dashlights not working 2004 S-10 Blazer
I just finished installing an aftermarket stereo. Now that I am done everything works except for when the headlights are turned on the instrument panel lights do not turn on. Also the temperature/compass light turns off (does not dim). Does anybody have any suggestions?
Old Sep 8, 2009 | 01:40 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
disconnect the illumination wire from your harness. It should be the orange or orane/white stripe wire depending on the brand of aftermarket radio. See if that does the trick for you...
Old Sep 8, 2009 | 06:21 PM
marctre's Avatar
Thanks for the reply. I tried that after the install and it did not work. The original install I connected the solid orange on the stereo which is Dash Light illumination. I then tried the orange/white on the stereo is for dimmer and that doesn't work either. I am really baffled by the fact that everything works perfectly fine until I engage the headlights. I am thinking it is related to the dimmer but if it didn't work I would think I would have blown one of the fuses.
mafiaboy01
Dec 11, 2011 01:13 PM
TAZ454
Dec 2, 2010 12:44 PM
jake25
Jan 12, 2010 07:09 PM
mikeywaynebygod
Nov 14, 2006 10:03 AM
evan_j
Oct 5, 2005 10:41 PM
