dbleon build thread
Old Feb 24, 2008 | 04:07 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default dbleon build thread
So i went ahead and gave it a shot... not too hard. I just copied the side panels for now. I have to wait to get components before fabbing up the rings and finishing it. Couple questions if I may:
How are rings usaually attached? Hot glue? Silicone?
Also can anyone reccomend a budget 6.5 component set? To be honest the only compnents I have ever heard were infinity kappa's. They were very nice. Im looking to spend under $150. I'm looking for a very warm smooth sound with GOOD midbass.
Here are some pics of the glass job.
Old Feb 24, 2008 | 04:40 PM
WolfPack's Avatar
Default RE: My first time fiberglassing...
From a non-fiberglasser's standpoint, those look pretty great!! Was it easier or more difficult than expected?
Old Feb 24, 2008 | 04:56 PM
dbleon's Avatar
It was actaully much easier than expected. The hard part was wrapping the glass sheets tightly around the panels. Hard to get it tight. They came out really sloppy at first, but a few minutes with a cutoff wheel and a die grinder straightened them right up.
Old Feb 25, 2008 | 04:50 PM
El_Beautor's Avatar
One way I've found to get the glass mat to form well is to cover the panel with masking tape, then spray it with glue. I use the same glue I use for carpeting sub boxes. I've found it works really well for panels with lots of contours, or even upside down. Once you get the first layer down, and let it cure you can take it out and add more layers if you need for strength. I did that when I glassed in the sub box in my wife's Mazda, and it formed amazingly well. It looked better than if the factory put it there. If I can find the pics, I'll post them.
Old Feb 25, 2008 | 05:25 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
good job fora first time. Few tips for the future. Use the matt that is made of strands, not the woven stuff. Tear the sheet into smaller pieces. cover the panel you want to FG with painters tape and use mold release or car wax to coat the tape. Apply the pieces of glass over the wax with the resin using a 2" paint brush and dab the resin into the matting. dabbing the resin will allow you to mold the glass to the piece and helps ensure that the resin gets absorbed into the glass better. When the resin hardens, remove the FG piece from the original. The wax will help in this part since the glass doesnt adhere to the wax.
Old Feb 25, 2008 | 07:00 PM
dbleon's Avatar
ORIGINAL: bobditts
I just used al foil and it worked well... came off easy. I dont know what kind of matt your talking about, i just used the bondo brand. And i did use (and ruin, hehe) a paintbrush ...
Thanks for the advice, its a learning process... I'll post pics as the progress is made. But im still in search of some decent compnonets. Any advice?
Old Feb 25, 2008 | 11:09 PM
bobditts's Avatar
whats your budget. here is the matt im talking about. As you can see it has hairs in it going every which direction.
http://www.jamestowndistributors.com...Fiberglass+Mat
this is the stuff not to use (unless you are making a surfboard or anyhting else with flat smooth surfaces.
http://www.jamestowndistributors.com...oth+-+10+Ounce
Old Feb 25, 2008 | 11:26 PM
dbleon's Avatar
This is what i used... same stuff just bondo brand. My price range for comps. is under 150.. Looking for the smoothest, warmest set for that price...
Old Feb 26, 2008 | 02:03 AM
thegr81's Avatar
Lookin good so far!! Look forward to the end result!!
Old Mar 23, 2008 | 06:00 PM
dbleon's Avatar
A little progress today... built the baffles. Hopefully next weekend the final fiber glassing will start.
