dbleon build thread
Old Mar 23, 2008 | 06:09 PM
blazinloud's Avatar
Default RE: My first time fiberglassing...
Looks great, nice job
Old Mar 23, 2008 | 06:10 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
looking good. Im guessing you used a jigsaw to cut the holes in your mounting rings (not to be confused with baffles)? Id suggest getting a router and a circle cutting jig if you want to make perfect circle cuts.
Old Mar 23, 2008 | 06:52 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
I have a router, but not a circle jig... I dont care that the rings are perfect, because the only thing that will be seen in the end is the rounded over edges. I still have to do some sanding to bring them up to my standards, but for my first try ever.... I think there pretty damn good (and they're flush mounts). I still need decide how to have the tweeters orientated... front or back? Also i think my parking brake is gonna be a prob. but i dont use it anyhow.
Old Mar 24, 2008 | 06:10 PM
oakleyg's Avatar
oakleyg is an unknown quantity at this point
ORIGINAL: El_Beautor
take it out and add more layers if you need for strength.
I would leave the piece on the part you are trying to mold because sometimes if you add more layers and its not on the original panel it can warp.
Old Apr 7, 2008 | 07:45 PM
dbleon's Avatar
Well finally got it all done... so here is a link to all the pictures. Feel free to check out the bikes too
Old Apr 7, 2008 | 09:33 PM
Blazin_Jason's Avatar
Looks good, got a couple questions. How come people don't just glass over the stock plastic kick panels and work off those? How do you have yours attached? Did you use your router with a flush bit to cut the holes out after glassing or something else?
Old Apr 7, 2008 | 09:39 PM
dbleon's Avatar
ORIGINAL: Blazin_Jason
I didnt use them incase i needed to put them back in there.
They are attached with one screw going through the back into the metal behind the panel. Holds VERY VERY snuggly
Yes, after glassing i just used my router to cut the holes out.
Old Apr 8, 2008 | 03:04 AM
theonetrueapex's Avatar
theonetrueapex is an unknown quantity at this point
Those look good. I look forward to the final pictures.
Old Apr 8, 2008 | 03:20 AM
dbleon's Avatar
ORIGINAL: theonetrueapex
Check my album 3 posts up... just have to carpet the sub enclosure is all
steelrfn
May 2, 2011 04:59 PM
tmurph01
Apr 17, 2010 02:36 AM
shmew22
Apr 1, 2010 05:28 PM
jayve bass
Mar 25, 2009 01:57 PM
bobditts
Oct 13, 2008 07:03 PM
