Digital Cluster
Old Mar 30, 2008 | 02:53 AM
curse's Avatar
curse is an unknown quantity at this point
Default Digital Cluster
I spent awhile now to find a online store to find a digital cluster for my 1994 s10 blazer, ebay is the only thing i can find. I'll call around the yards around town but is there a known store that sells these things? I'm tired of analog, the gas gauge is screwy and I have problems reading it with the poor backlight it has.
Old Mar 30, 2008 | 10:57 AM
neo71665's Avatar
Default RE: Digital Cluster
Are you sure its the gas gauge and not the sender, replacing the cluster won't help if its the sender. If you replace the 194 bulbs in the analog cluster with LEDs it makes the whole thing brighter and its cheaper and easier than to swap to a digital.
Ebay or a junk yard about the only places your gonna find a factory digi cluster. FYI the factory digi clusters are known for having a weak power supply and bad solder joints in them so you might want to either make sure this has been addressed or fix it yourself before you go through all the trouble of swapping it out to have to pull it in a month to fix.
Dakota digital sells a plug and play digital cluster, its about $600 but I'm gonna say is better than the factory ones.
Old Mar 30, 2008 | 11:03 AM
curse's Avatar
Althought I am familiar with a soldering iron, im not so much when it comes to complex circuitry. I'll see how much the yard's are, i'll probably do the LED idea. 600 dollars wow, it does look nice and has alot of need-to-know info on it.
Old Mar 30, 2008 | 01:02 PM
94blueknight's Avatar
94blueknight is on a distinguished road
u could just hook up another gas gauge and mount it to the a-pillar or somethin
3kidblazer
Feb 1, 2009 11:22 PM
91 Streeter
Mar 17, 2008 10:25 PM
error_401
Mar 17, 2008 06:39 PM
smokey94
Nov 11, 2006 10:15 PM
smokey94
Nov 6, 2006 06:06 AM
