digital cluster
digital cluster
i have a 91 blazer with the crappy cluster and i was wondering if i could change it to a digital cluster? i know the plugs in the back are different but the wires to each plug should be the same right? so would i be able to splice the wiring harness into the new plug for the digital cluster? are there any wiring diagrams? thanks
RE: digital cluster
RE: digital cluster
thanks but i was asking because i already have a digital gauge cluster from an 89 with same size motor and trans and everything
RE: digital cluster
oooooohhhhhhhhhhhhhhh blah
my bad bro. (late/long night)
you might be able to splice in. I'm not sure how well it'll work tbh.
I could look around and let you know though
RE: digital cluster
thanks. the splicing wont be a problem i do good work i just hope i can match all the colors[:'(]
RE: digital cluster
tore apart my dash today and the plug on the digital cluster has one more wire on it than the stock one. they all have the same colors i think there might be an extra ground on the digital one? any help? suggestions?
RE: digital cluster
extra ground?
Just ground it!
should work like a charm then
Just ground it!
RE: digital cluster
haha i think the digital cluster has two black wires thats why i said that. when i get the time im gonna rip the whole dash apart and splice the wires and see what happens haha
RE: digital cluster
Be careful while your doing this.
dont toast your electrical
RE: digital cluster
im gonna do some research on it first try and find a diagram with the colors or something. im not gonna cut the wires from the stock plug im gonna use those splice into clips that you basically crimp into the line. hopefully i can find something
