Distribution block help!
Old Jun 30, 2008 | 02:55 PM
oceaneyes823's Avatar
oceaneyes823 is an unknown quantity at this point
Default Distribution block help!
What kind and size of distribution block do i need for my 2 amps in a 95 blazer?
Old Jun 30, 2008 | 03:18 PM
rkilgore's Avatar
rkilgore is an unknown quantity at this point
Default RE: Distribution block help!
How powerful is your amps?I have 2 blocks in my blazer,One for positive and other for negative,I have 4 gauge coming out of the block to my battery and two 8 gauge coming out the other end of the block to my amps.
Old Jul 7, 2008 | 11:58 PM
splblazer's Avatar
splblazer is an unknown quantity at this point
you dont need a block unless your running multiple amps. skip the block and run it straight to the amp. with a inline fuse on the power. if u have a 4 channel amp and a sub amp u will need 2 blocks one for power with 3 connections and another for the ground with 3 connections. if your having problems fitting your power and ground in the amp inputs. they make neck down connectors that u can use to go from 1/0 guage to 8guage.which is the normal amp input wire size.
sparky672
Oct 11, 2010 09:42 PM
lil_blazin
May 10, 2009 05:20 PM
HHimmy
Apr 5, 2009 07:34 PM
fondo
Nov 16, 2008 03:11 PM
bestes
May 31, 2008 03:16 PM
