Oil line adapter block on motor (HELP!!!)
Old Nov 15, 2008 | 01:07 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Oil line adapter block on motor (HELP!!!)
I replaced my oil lines last weekend (motor to filter) thought I was good to go, check oil today and my oil line has already dropped half way down the dip stick. Sure enough the adapter block is leaking. I went to napa and picked up an o-ring and gasket set (felpro) for the adapter block. There are 2 small o-rings, 4 mediums size o's, 1 rather large o-ring, and 2 gaskets that are different from each other. Now the kit says it fits s-10's from '04 back to 1985. So Im wondering if some of these rings and gaskets are for different years. Has anyone ever replaced these (1st or 2nd gen), if so what all do I need to do. I've searched but haven't found anything. I need input asap please. Much appreciated
Old Nov 16, 2008 | 03:11 PM
fondo's Avatar
Default RE: Oil line adapter block on motor (HELP!!!)
Well I'm glad I got that over with. If you have the cpi motor (vortech emblem on plenum), here's a brief walk through on how to change adapter block gasket and o-ring. I recommend changing the gasket and o-ring especially if you install new oil lines. I learned this hindsight when my truck started to leak after I installed the new oil lines. The increase in pressure being exerted on the adapter block gasket and (brittle) o-ring finally blew one or the other out and eventually caused a rather drastic leak. But all is well so far.... So heres the run down:
Parts & Tools needed:
-Oil line adapter block o-ring/gasket kit found at your local parts store (My local napa had a felpro kit in stock for $4.00). Kit includes 2 small o-rings, 4 medium o-rings, 1 large o-ring, and two different shaped gaskets. For the cpi motor you will need the large o-ring and one of the two gaskets included (you'll know which one you need when you pull the adapter off the motor).
-5 quarts of fresh oil and filter
-Brake parts cleaner
-15mm, 14mm, and 13mm sockets and wrenches w/ 3/8" drive socket
-3 foot extension or equivalent w/shorter wobble head extension. (May be able to use u-joint instead of wobbly)
-petroleum jelly or wheel bearing grease
-gaskest scrapper or razor
-Shop light or equivalent
-Flat head screw driver (long)
-Floor jack and stands
-Lug wrench
1. Loosen front driver side lug nuts, properly suspend vehicle using suitable jack and jack stands. Remove drivers side wheel.
2. Remove oil drain plug using 14mm wrench. Catch oil in drain pan.
3. Undo hose clamp and remove air cleaner box
4. Remove oil line clamp located just underneath power steering pump using a 13mm socket w/ ratchet.
5. Feed extension through the engine bay from beneath the radiator shroud until you lock on with the oil line bolt that secures the oil lines to the adapter block. In this step you'll need the long extension (3') coupled with the wobbly extension and a 13mm socket and of coarse your ratchet driver.
6.Place drain pan beneath oil line to adapter junction to catch oil still remaining in lines. Gently tug on oil lines to break seal on adapter block and pull lines back away from the adapter block *Now is a good time to remove the oil filter so the oil in the lines can completely be evacuated. This will depressurize the hyrdrolock and allow all the oil to escape.
7.Crawl under truck and locate the oil line adapter block, it is just above and behind the front diff carrier(if you have 4wd), it will have to 13 mm bolt heads that srew into a bowl shaped peice. Once located you'll notice a steel shield right below the adapter block with two 15 mm bolts fastening it to the diff carrier. You'll need to undo these two bolts so you'll have enough room to work on the adapter block. You cannot remove these bolts completely because there is not enough clearance between the oil pan and the carrier where they attach.
8. With the steal shield pushed aside, undo the the two 13mm bolts holding the oil adapter block to the engine block. Carefully lower it as far down as you can and flip it on its side so you can remove and replace the outer o-ring and the inner gasket. *As far as I can tell you can't remove this adapter without undoing the drivers side motor mount and jacking up on the oil pan to nudge the motor out of the way. I replaced the o-ring and gasket without doing this however.
9. Scrap old gasket material of mating surfaces with gaskets scraper or razor and remove larger outer o-ring (see how brittle it was).
10. With all the twisting and turning you'll be doing with the adapter, it gonna collect grime and dirt. I suggest spraying it down with some brake parts cleaners and allowing it to dry before attaching gasket/o-ring and re-installing assembly.
11. Apply a thin film of oil to the o-ring and dab with grease to keep it from falling out of its groove upon installation. Now dab a very small amount of grease or petrol jelly to the gasket so it will adhere to the mating surface and will not fall off upon assembling.
12. Attach gasket either to engine block mating surface or adapter block mating surface, what ever works for you. This may take sometime to get right so be patient. An extra set of hands or a long screw driver to hold adapter up while you shimmy it into place may be helpful. Again this is the most frustrating step, so what ever you can use to your adavantage I would suggest using. Have that shop light handy.
13. Once adapeter block is in place be sure the o-ring and gasket are properly seated and torque the two 13mm bolts anywhere from 15-25 foot lbs.
14. Re-fasten steal sheild and oil drain bolt if you haven't already.
15.Through the fender well, pull up the dust curtain and locate the oil lines. Press fittings back into adapter block. Thread bolt into adapter and torque to15-25 foot lbs.
16. Re-attach hose clamp under power steering pump and secure. Carefull not to over tighten or you can crimp or even puncture the oil lines.
17. Install oil filter if you haven't already and add 4.5 qts of oil
18. Install air cleaner box and all the necessary vaccuum lines.
19. Install wheel and lugs
20. Remove jack stands and lower vehicle. Tighten lugs nuts.
21. Start truck, check for leaks... Repeat steps 1-20 if leaks are found.
Additional steps are necessary if replacing oil lines.
THIS IS INTENDED ONLY FOR THE VIN W CPI MOTOR WITH VORTECH EMBLEM (4wd)1993-1995. I WILL NOT BE HELD RESPONSIBLE FOR ANY DISCREPANCIES OR MIS-UNDERSTANDINGS THAT MAY OCCUR.
GOOD LUCK
rrtx2000
Sep 16, 2013 11:18 PM
adamscottmartin
Jun 26, 2013 11:31 AM
Toby Hanson
Jun 18, 2013 01:06 AM
cleburne red
Jan 28, 2013 04:53 PM
buck
Feb 16, 2009 01:22 PM
