Do I need the big 3?
Old Sep 20, 2015 | 04:13 PM
Bieszki95's Avatar
Bieszki95 is on a distinguished road
Default Do I need the big 3?
I've got an 04 blazer. Currently running less than 1k in ca audio. However, I plan to run more than one amp and add subs into the package, nothing more than 3k watts. Should I purchase a HO alternator and Upgrade the wires? Or is adding a 2nd battery enough. Any input would help a lot before I go make a purchase I don't need.
Old Sep 20, 2015 | 05:19 PM
Thogert's Avatar
A second battery only adds more capacity, not generation. So if you listen to the system for a long time at high levels, you'll kill your stock alt, and drain both batteries. An upgraded alt is a better purchase than a second battery. If the alt has a hard time, then get a second battery.
For the original question, yes, definitely do the big 3 if you are pushing that much power. Stock wire size is like 6 or 8 ga.
Here's a chart on wire size vs amps vs length
3KW @ 12V = 250A
Depending on if you are talking RMS or peak, you should have larger wires either way. Fire = bad
ON THA LOW
Oct 5, 2011 08:23 AM
dakine7676
Jun 13, 2010 08:04 PM
derrilyktdave
May 18, 2010 10:09 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
