dome light problems
Old Mar 3, 2007 | 02:28 AM
bgillette78's Avatar
bgillette78 is an unknown quantity at this point
Default dome light problems
i have a '99 blazer and the dome light seemed to quit working when the doors are open. if you switch the dimmer switch all the way up they will still come on and when i use the keyless entry they come on. the radio and lights still turn off when i open the doors. so i am not sure if it would be the door switches or the actual headlight/dimmer switch that would have to be replaced. any help would be great.
Old Mar 3, 2007 | 02:33 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: dome light problems
You might have turned the dome light over ride on. It is a little button right below the headlight switch. Try pushing the button in with the door open and see what happens. HTH Korey
Old Mar 6, 2007 | 08:23 PM
the headlight switch does not have the dome over ride switch on it any other suggestions
Old Mar 6, 2007 | 08:38 PM
drperry's Avatar
There's no little button near the headlight switch? That's odd...
If that's not the case, there might be a burnt fuse somewhere...
Old Mar 6, 2007 | 09:29 PM
ya i thought that was odd too most GM cars have them. and the fuse is good because the dome light still comes on if the dimmer switch is pushed all the way up and the keyless turns the light on also
Old Mar 6, 2007 | 10:18 PM
drperry's Avatar
There might be a fuse for the door sensors, or else at least ONE of the doors would make the light come on...
Old Mar 6, 2007 | 10:58 PM
i dont know then. i will check it out. i might as well just buy a new one since i dont have the dome over ride on it
Old Mar 7, 2007 | 03:45 PM
well i checked the door switches and the passenger side was busted and the drivers side was stuck in. just wiggled it out and it works fine. thanks guys
Old Mar 7, 2007 | 06:12 PM
drperry's Avatar
Good to hear ya got it fixed!
Guess I should've asked if the hatch still makes the light come on, lol
97blazer8488
Nov 4, 2015 04:48 AM
dano440
May 11, 2012 06:57 PM
necropenetrator
Oct 26, 2009 09:55 AM
otter360
Aug 28, 2008 10:54 AM
ChrisAttebery
Jul 9, 2007 12:53 PM
