Double Din
Old Jan 2, 2014 | 03:10 PM
HeavyChevy123's Avatar
HeavyChevy123 is on a distinguished road
Default Double Din
I Have A SSL DD888 i want to put in my 2001 blazer but its taller than the stock hole from the original stereo what do i need to do to make it fit
Old Jan 3, 2014 | 07:32 AM
the DJ's Avatar
the DJ is on a distinguished road
A hacksaw and the guts to cut up your dash.
Did something like that few years ago:
click here to see my handywork at showyoursound.nl
Old Jan 3, 2014 | 11:07 AM
LeWhite's Avatar
Later Blazers have a double DIN facia for the dash. Grind not cut the frame of the dash with a dremel or die grinder as it only takes a little. There might be clearance issues to the rear at a heater duct. That can be remedied with a heat gun and a gentle push. Again only a little as there are other heat sensitive parts around. Remove air bag fuse and disconnect battery first. The adapter jack rattles around so rap it with a little foam. Good luck, now get after it!
Old Dec 28, 2014 | 01:09 AM
Motocross16's Avatar
Motocross16 is on a distinguished road
I used the dash from a 2001 Bravada for my double din install. Everything matches up the same, just has a bigger opening for the stereo. No cutting or trimming was needed.
msu12
Jun 14, 2019 12:33 AM
julioAKAjunior
Oct 9, 2012 11:29 AM
97Beater4WD
Feb 15, 2012 12:17 PM
fatcats2001x
Dec 5, 2009 11:03 AM
Arthur
Mar 20, 2008 05:42 PM
