Factory Radio Removal
Old Nov 9, 2008 | 07:42 PM
ne1's Avatar
ne1
ne1 is an unknown quantity at this point
Default Factory Radio Removal
Any instructions for removing the factory radio from a 1995 Blazer. I tried the ones that came with the install kit (94-97) but the removal of the knee bolster was no where near what this truck has. I worked for 2 hours trying to get this thing out but have stoped. The truck has a column shifter (automatic) which makes it look impossible to get the dash bezel off around. I can get everything but the bezel away from the steering column.
It looks like the knee bolster under the steering wheel neds to come out becase there are metal tabs that stick up and obstruct the dash bezel from pulling up around the wheel. But to remove the knee bolter it looks like a 2 other plastic pieces need to come out.
Can all this be right. remove 1/2 the dash to get a radio out. If so, GM should be ashamed of themselves.
Thanks in advance for any help.
Old Nov 10, 2008 | 07:05 AM
jagblazer01's Avatar
Default RE: Factory Radio Removal
take and put the emergency brake on and put your shifter down into 1st gear.....bezel should come off
Old Nov 10, 2008 | 04:24 PM
kdanderson5's Avatar
kdanderson5 is an unknown quantity at this point
ORIGINAL: jagblazer01
+1 on this. If it is like a 96 (which I think it is) be careful about the hazard lights ****. I busted mine off the other day tearing the dash apart to install my remote and rca wires. Believe it or not the bezel can actaully take a lot of flexing without breaking as long as it is not freezing out like it is here in Iowa now.
May sound like dumb advice, but make sure your 4x4switch, lights, interior lights etc... wiring is all unhooked. You don;t need the added problem of busting some of that off! I know for a fact haha!
Old Nov 15, 2008 | 05:16 PM
dave5point0's Avatar
dave5point0 is an unknown quantity at this point
lol, you joke about half the dash having to be removed.... you should try a 96 and up cavelier.... waaaaaaaaaay more fun, the entire top dash pad has to come out to get the radio out, i've done em blindfolded before though :-)
Old Nov 15, 2008 | 06:30 PM
ORIGINAL: dave5point0
lol i know about that....my girlfriends sister has an 03 cavy...i think its that year...and we installed an aftermarket deck in it...not much fun lol
02Goldie_Loks
Tires and Wheels
Aug 11, 2015 06:49 PM
SWANNERZ
Aug 13, 2014 05:05 PM
Boiler20
Oct 19, 2013 03:53 PM
blazerwithballs8
Mar 12, 2009 08:47 PM
cool2drblazer
Apr 27, 2006 01:00 AM
