FatMat sound deadening project
Old Oct 17, 2010 | 08:44 PM
dwhittaker's Avatar
dwhittaker is on a distinguished road
Default FatMat sound deadening project
About to fatmat the entire interior, ripping apart every panel. ripping out any factory insulation, Wish me luck
Old Oct 17, 2010 | 11:05 PM
JShark's Avatar
JShark is on a distinguished road
luck. get lots of pictures.
nice front bumper and toss those tpe r's on 1000 rms, you wont want to go back to that 500.
welcome to the fourm btw
Old Oct 18, 2010 | 09:32 AM
dwhittaker's Avatar
i'll have them running RMS soon enough, i'm looking for another m501... strap 'em together and get louder. $$ is the problem currently.
Old Oct 18, 2010 | 03:06 PM
blazinloud's Avatar
those amps definatly got some KICK
Old Oct 18, 2010 | 07:23 PM
MTopper's Avatar
good luck with that. i did that this past summer in my 2 door using Raammat BXT. it was a sticky pain in the butt, it did pay off after though
Old Oct 24, 2010 | 05:26 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
Why FatMat? And why the entire interior? Personally, if I'm going to that much work, it will be Second Skin, or the guy mentioned in the sticky above in this section. And anything over 50% coverage is a waste. Some even say 25%. Load the center of the large flat pannels and be done with the vibration mat. FatMat, Dynamat, etc. are only vibration dampers. They aren't noise barriers.
Old Oct 25, 2010 | 10:36 AM
dwhittaker's Avatar
actually, fat mat, dynamat and what-not keep sound in. by sealing off possibly leaky panels, or panels that echo, it keeps in air pressure, and by doing so, increases the Db, and the overall sound quality. just like foam baffles on the walls of studios, it controls the sound.
plus the only thing that rattles on my blazer is the lift gate and the rear vents. and i'll be using fat-mat because i'm not going to pay that much for mat.
$100 for 100sq ft isn't bad at all.
Old Oct 25, 2010 | 01:55 PM
MTopper's Avatar
if you want to completely deaden your truck you might want to go with some ensolite and MLV. i have MLV on the floor on top of my deadening and its quiet like no other.
my truck only rattles when i'm on crappy Detroit roads. system on full doesn't do anything so i'm set
Old Nov 1, 2010 | 01:52 PM
blazinloud's Avatar
peel n seal, same ****, fraction of the cost, and readily available locally.
on top of what was mentioned it also greatly reduces road noise, helps keep heat/cold in, and is well worth doing even if you dont have bass.
i have e-dead v-1 i think, has held up for 4 years now in canadian climate, still stickin'.
but when i do it again it will be with peel n seal and possibly some rocker guard, cheap cheap.
swells87
Oct 10, 2013 11:12 AM
uhlhazard
Oct 18, 2011 12:08 AM
Big Frost
Jul 22, 2008 02:21 PM
tylersilva12
Aug 15, 2007 05:37 PM
jagblazer01
May 17, 2006 07:40 PM
