-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Finally buying amp (https://blazerforum.com/forum/audio-video-electronics-8/finally-buying-amp-18300/)
dimmuborgir6nik6 Mar 13, 2008 01:12 AM
Finally buying amp
Looking at a few new different types
4 <<< The original amp I wanted to get.
Since I have 2 amps running at 1500W, wouldn't a 3000W be needed to run the highest? One thing I still haven't mastered is subwoofers and amplifiers..
mdehoogh Mar 13, 2008 01:22 AM
RE: Finally buying amp
i cant say from experience but i dont think the BOSS and SOUNDSTORM amps are very good
jagblazer01 Mar 13, 2008 07:15 AM
out of all those id go with the hifonics
blazinloud Mar 13, 2008 07:57 AM
yea man, those are marketing scams...no way in hell they put down 3500 watts, or ANYWHERE near that. save your money.
dbleon Mar 13, 2008 01:32 PM
If you need 1000w TRUE power... buy this cadence. Hands down will kick ass agianst any of those amps you have listed. FTW!
cloak01ls Mar 13, 2008 01:55 PM
First of all. Get those Wal-Mart power numbers out of your head. "RMS Wattage" is the only thing you should concern yourself with as far as power...Its fairly simple to match a sub with an amp, you just have to know some simple things.
Find out what final ohm load you need (I.E. D4 + D4 = 4/1ohm)
Then find out what RMS wattage you need (I.E. 500wrms + 500wrms = 1000wrms)
-this number can vary quite a bit, running 10-15% over the number you need is not a bad idea and wont hurt the subs as long as you tune your amplifier properly.
Then the rest is just researching brands and gettign the best bang for your buck...
jagblazer01 Mar 13, 2008 05:09 PM
what is your budget for the amp and what is the sub setup ur running?
dimmuborgir6nik6 Mar 14, 2008 12:57 AM
Right now I'm at about $300 or a little over, and I'm running 2 15" Alpine Type R's, the new versions.
blazinloud Mar 14, 2008 07:31 AM
dual 4's?
you may want more than 600 each
dimmuborgir6nik6 Mar 15, 2008 03:08 AM
600 RMS on 4-ohm?
