Finally buying amp
First of all. Get those Wal-Mart power numbers out of your head. "RMS Wattage" is the only thing you should concern yourself with as far as power...Its fairly simple to match a sub with an amp, you just have to know some simple things.
Find out what final ohm load you need (I.E. D4 + D4 = 4/1ohm)
Then find out what RMS wattage you need (I.E. 500wrms + 500wrms = 1000wrms)
-this number can vary quite a bit, running 10-15% over the number you need is not a bad idea and wont hurt the subs as long as you tune your amplifier properly.
Then the rest is just researching brands and gettign the best bang for your buck...
