Fog Lights fitted into clear corners?
Old Feb 26, 2009 | 11:43 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Default Fog Lights fitted into clear corners?
So i was wondering if anyone has ever done this before. I know that there are factory type set ups but i was wondering if anyone had modified there stock corner lights and has taken advantage of the empty spot in the lens. BTW this is on a 2003 blazer.
Old Feb 27, 2009 | 02:51 AM
mdehoogh's Avatar
Default RE: Fog Lights fitted into clear corners?
My truck has the OEM fog lights in the place you're talking about. I can't say with certainty but I believe that "empty spot" in the lens (at least, the stock lenses) will not allow for a lightbulb/reflector. I thought I had seen some pictures of the stock corner lights and in the spot you're talking about, it was just flat.
I know one person on this forum had some aftermarket clear corners that modified them to fit a bulb in the empty spot. So yes, with aftermarket turn signals, I'm sure it's possible to modify them but I don't think you can with the stock turn signals.
Old Feb 27, 2009 | 07:24 AM
jagblazer01's Avatar
not 100% sure on the stock ones....I know I fitted my aftermarket ones with a strobe light bulb and it wasnt hard at all
Old Feb 27, 2009 | 02:46 PM
kiwiblazer's Avatar
I've done this with my aftermarket lenses but see no reason why the oe ones can't work. I've used the extra slot for another turn signal. You will need to cut away the clip at the back & refit the lense to the billet grill. Mine now comes out as one piece. Grill with the bumper lights.
[IMG]local://upfiles/9926/A68872F247AF4FA6BD382021D7724603.jpg[/IMG]
[IMG]local://upfiles/9926/BB76256946224F42943C1259841B3211.jpg[/IMG]
Fourstar200
Dec 28, 2011 12:41 AM
Mr Blazer LT
Aug 12, 2009 12:12 AM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
2000WhiteZR2
Jul 26, 2005 09:20 PM
Blaize70
Dec 24, 2004 02:25 AM
