fried??
so my amp in protection mode replaced blown fuses check wires nothing...... so does this sound like it is fried??
more info :
i had it in my dads tbird and sure i was hooking it up, it worked fine for about an hour, got home was going to put it in my truck again and then it just blew
i hooked it up the exact same way i have all the time before going to go money around a bit more before i decide to junk it (its a Dual Audio amp or something)
more info :
Do you have a multimeter? if so what are your readings on the power and remote with the vehicle running, and using the amp ground as your ground reference for your meter?
How many subs are you running on this amp? What impedance is the amplifier currently seeing?
dont know,dont know,dont know, i am running 1, and dont know
well.... let him look and then get back to it. before i became an audio nutjob i couldn't tell you what ohm my subs were or how much power they were getting... now i can ramble everything off the top of my head no problem
vetteandblazerman
Sep 19, 2009 09:57 AM
