front door speaker help
ok so i took the door panel off to replace a busted mirror that someone clipped off driving by... now with the excellent luck i have, i punctured a hole in the door speaker with the door panel clip...it was a pioneer 6.5 2way... im looking into a pair of kicker ssmb6 6.5 mid bassy type woofers? good idea? or will they rattle the hell outta my doors? i already have 4.5 2ways in the dash. i have no amp or special door linings to dampen vibration nor do i intend to add those things... maybe i should just stick with the 2way 6.5? please help...
Does the punctured speaker still work? I've never done that to a speaker but unless you damaged the voice coil, the cone itself should still move and produce sound.
I looked up the specs on the SSMB6. It should be better at producing lower freq's than the Pioneer's you have but without an amp I doubt you'll get the full effect of those woofers.
speakers will always sound better when you put proper power to them, like a 4 ch amp. decks have a harder time actually being able to drive a larger speaker, like a mid bass or sub. the power they actually put out is around 10-15 RMS, which is not really a lot when you think about it. for tweeters its ok, but the larger the driver the more power you need to move it. hope that helps lol, i think putting mid drivers into the doors has the potential to sound good, but without an aftermarket amp, will your deck be good enough? not sure.
xJakeLIKEShisBLAZERx
Mar 22, 2014 09:59 AM
c3478493
Feb 3, 2014 02:56 PM
dano440
May 5, 2012 11:32 AM
iL8on
Oct 18, 2009 09:14 AM
