front door speaker help
Old Jan 2, 2009 | 02:27 PM
robjamber's Avatar
robjamber is an unknown quantity at this point
Default front door speaker help
ok so i took the door panel off to replace a busted mirror that someone clipped off driving by... now with the excellent luck i have, i punctured a hole in the door speaker with the door panel clip...it was a pioneer 6.5 2way... im looking into a pair of kicker ssmb6 6.5 mid bassy type woofers? good idea? or will they rattle the hell outta my doors? i already have 4.5 2ways in the dash. i have no amp or special door linings to dampen vibration nor do i intend to add those things... maybe i should just stick with the 2way 6.5? please help...
Old Jan 2, 2009 | 09:55 PM
mdehoogh's Avatar
Default RE: front door speaker help
Does the punctured speaker still work? I've never done that to a speaker but unless you damaged the voice coil, the cone itself should still move and produce sound.
I looked up the specs on the SSMB6. It should be better at producing lower freq's than the Pioneer's you have but without an amp I doubt you'll get the full effect of those woofers.
Old Jan 2, 2009 | 10:01 PM
Cyron's Avatar
Cyron is an unknown quantity at this point
speakers will always sound better when you put proper power to them, like a 4 ch amp. decks have a harder time actually being able to drive a larger speaker, like a mid bass or sub. the power they actually put out is around 10-15 RMS, which is not really a lot when you think about it. for tweeters its ok, but the larger the driver the more power you need to move it. hope that helps lol, i think putting mid drivers into the doors has the potential to sound good, but without an aftermarket amp, will your deck be good enough? not sure.
Old Jan 3, 2009 | 10:05 AM
blazinloud's Avatar
i have my pioneer h.u running a pair of JL comps and it sounds ok.....dont expect bass out of a h.u.........amping will be a night and day difference....
Old Jan 3, 2009 | 09:09 PM
mdehoogh's Avatar
ORIGINAL: blazinloud
x2
Old Jan 4, 2009 | 10:24 PM
robjamber's Avatar
thanks...
xJakeLIKEShisBLAZERx
Mar 22, 2014 09:59 AM
c3478493
Feb 3, 2014 02:56 PM
dano440
May 5, 2012 11:32 AM
tomcat408
Jul 1, 2011 02:36 PM
iL8on
Oct 18, 2009 09:14 AM
