Fuse Size?
Old Mar 30, 2009 | 07:28 PM
blazerwithballs8's Avatar
blazerwithballs8 is an unknown quantity at this point
Default Fuse Size?
I am getting ready to hard wire a radar detector and i am running it to a new fuse in the fuse box. what size fuse should i order (not the ampage) like is it a mini blade fuse or normal size? thanks
Old Mar 30, 2009 | 08:04 PM
I would just use the regular size fuses, not the minis. Just easier to deal with.
Old Mar 30, 2009 | 08:39 PM
will the regular fit in the fuse box though?
Old Mar 31, 2009 | 12:40 PM
How are you wiring this into the box? An open position? What are you using for the contacts in the box? Why not just find a switched ignition source wire (radio power) and tap into it with a 3A or 5A fuse?
Old Mar 31, 2009 | 04:25 PM
i plan on just running this to an empty fuse:
http://www.radarbusters.com/radar-de...ircuitmini.cfm
Old Mar 31, 2009 | 06:12 PM
OK... You do not plug that into an empty fuse, you find a fuse that has the power when you want it (ignition switched or constant - you want ignition switched) and piggy back off of it with the item you linked to. The radio fuse would be a good candidate.
Then you question is what size to get...? Well, you have to match the fuse size for the circuit you are planning on jumping off of.
Old Mar 31, 2009 | 08:12 PM
ok since that has 2 fuses one will be for the radio and the other would go to the radar detector? and i plan on using a 5 amp.
ps thanks a lot for your help appericate it
Old Mar 31, 2009 | 08:31 PM
That would appear to be how it is intended to work.
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
cno561
Nov 11, 2010 10:01 AM
jag2791
Nov 5, 2009 06:49 PM
Sherwood
Oct 12, 2007 09:21 PM
