head unit help
head unit help
hey i wanna put a head unit in my truck that has a dvd player in it and a pop out screen where can i find one farely cheap and will it drain alot of power when using it as a dvd player?
define cheap please.
i have seen them as low as 250 all the way up to 3000. what area are you looking for and are you looking for built in Ipod, navigation, phone bluetooth, ect?
for cheap you could hit up the local wal-mart and get a Dual brand flip out. really basic options but under 300 bux.
im looking for one under 500 and i want it to have a cd changer and dvd player mainly
http://onlinecarstereo.com/CarAudio/...-P6000DVD.aspx
here is what i have found. its the only one i know of with built in changer but its double din and over budget. i would suggest a cheapish flip out then add on a cd/mp3 changer after.
ok thank you well i have a built in 12 cd changer do you know of any other that are good and in my price range?
also i would like to have a rpm gauge, speedometer, etc in it also
you want cheap, you get cheap. You get what you pay for. You are asking a lot for under $500
Ive never heard of/seen one with a Tachometer or a speedometer. Look for one with GPS/NAV, and it MIGHT be able to tell you your speed.
ok how are the ones from wally world? and will it be using alot of power from my truck or should i get a power converter?
you wont need a power convertor, it wont use that plug. it wires into the truck just like any other aftermarket cd players. and it will pull under 15 amp for sure, if not under 10. the only way you will have any issues with your trucks power in relation to the dvd unit. if you wire it off a bit so there is a short, then the battery will die, or if you sit and play it for hours on end with the truck off the whole time, then it will drain the battery. but all in all - the dvd flip out units wont pull enough to make any diffence in a stock system and you will only use the same install harness and dash kit as any other single din cd unit.
