head unit wiring ugh can anyone help me
Old Oct 20, 2006 | 09:03 PM
blazer123456789's Avatar
blazer123456789 is an unknown quantity at this point
Default head unit wiring ugh can anyone help me
ok im am tring to put in a jensen dvd player head unit the problem is i dont no the what each wire is for from the old hu it is a delco model # 09383045 i need to no what each wire is for, that goes in to the back of the stock delco player.. the color codes
on the wire harness that plugs into the delco there is 9 wires on top of the plug and 6 on the bottom hopefully someone can help me all yea my blazer is a 2 door year 2000 if it helps
Old Oct 20, 2006 | 10:37 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: head unit wiring ugh can anyone help me
Here ya go...let me know if you need help......and welcome to the forum!!
[IMG][/IMG]
Old Oct 21, 2006 | 12:21 AM
this schamatic has 3 drk greens and i no there arnt 3 dark green wire on the plug i can tell u what color wires there are and what order they come in if u can help i would appricaiate it
Old Oct 21, 2006 | 01:34 AM
hillbillyinOhio's Avatar
did you buy the wiring harness(Metra part number 70-1858, Scoshe is GM02B)?? if not you will have to cut the factory plug, I don't recommend, but the wiring is as follows.
12v constant is Orange - connect to yellow wire in jensen plug
12v switched is yellow(larger wire) - connect to red wire in jensen plug
ground is black, connect to black in jensen plug
ignore the grey and brown, for must and illumination. don't worry about them
Speakers are
Left Front
Tan is positive - connect to solid gray on jensen unit
Grey is negative - connect to gray with black tracer on jensen unit
Rt Front
Lt Green is Positive - connect to solid white on jensen unit
Dk Green is Negative - connect to white with black tracer on jensen unit
Left Rear
Brown is positive - connect to solid green on jensen unit
Yellow(smaller wire) is Negative - connect to green with black tracer on jensen unit
Rt Rear
Positive is Dk. Blue - connect to solid purple wire on jensen unit
Negative is Lt. Blue - connect to purple with black tracer on jensen unit
thats it. please use some kind of crimpers (crimp caps, butt connectors) on the wiring connections. tape is not sufficient
Old Oct 21, 2006 | 11:50 AM
there is only one yellow wire ? hopefully u no what i can do
Old Oct 21, 2006 | 02:04 PM
do you have a voltmeter???? meter it.
Old Oct 22, 2006 | 10:26 AM
Moved to 'Audio/Visual'
Old Jan 11, 2007 | 11:26 PM
dcblazer's Avatar
dcblazer is an unknown quantity at this point
sorry about that i don't think i was searchin the right things thanks for the links they were very heplful........
jmathis7113
Jul 25, 2014 09:47 PM
SubbinBlazer
Apr 5, 2013 09:17 PM
89Recon
Jul 29, 2012 12:39 AM
chriswf
Feb 4, 2008 11:52 PM
1989Blazer269
Oct 26, 2006 12:15 AM
