Hella Lights
I hooked up some Hella 550ff lights this weekend. I originally had them installed on an Isuzu Rodeo years ago. I hooked them up following the wiring diagram. I tapped into the low beam power wire since in Pennsylvania fog lights must only operate with the low beams. However, they come on with the low beams, which they should, but do not go off when the high beams come on. I used the original wiring harness/relay that came with the lights. The only thing that is different is the switch I used. There are 3 wires leading to the switch (power/load/ground). The switch I used does not have a ground terminal, so the ground wire does not hook to anything. I figured the ground was just to operate the light on the switch so that shouldn't be the problem. Could the relay be bad. It must be working if the lights come on only if the low beams are on. Any ideas would be helpful.
Thanks
Thanks
CH@Dbee
Dec 7, 2009 07:41 AM
BlazinMike89
Feb 25, 2009 10:26 PM
