help
Old Apr 10, 2008 | 07:40 PM
tjbmxrider's Avatar
tjbmxrider is an unknown quantity at this point
Default help
i need to know what kind of wires i need to go from my amp to my sub. not the brand the type of wires.
Old Apr 10, 2008 | 07:50 PM
94blueknight's Avatar
94blueknight is on a distinguished road
Default RE: help
use speaker wire but depending on how powerful ur subs r will make the gauge diff. if its a basic set up i'd go w/ 8 gauge.
Old Apr 10, 2008 | 08:44 PM
mdehoogh's Avatar
Default RE: help
8ga is a little big from the amp to the subs.
i have a 750W rms amp and I'm using 12ga wire from the amp to the sub.
any wire will work, i picked up two $4 spools of 12ga wire at radioshack. one black and one red
Old Apr 10, 2008 | 09:01 PM
enochian's Avatar
enochian is an unknown quantity at this point
Default RE: help
I would use the shortest wire you can of 10 guage myself. If the subwoofer is ratedfor a specific guage use that guage. Otherwise you should go with bigger wire just to be safe... The less resistance the less likelyyou will be to short out your AMP.
Old Apr 11, 2008 | 01:53 PM
tjbmxrider's Avatar
Default RE: help
well i have a 1000 watt amp made my kicker and a 15 inch L7. What gause wire should i get for that?
Old Apr 11, 2008 | 08:45 PM
hillbillyinOhio's Avatar
Default RE: help
get 12 gauge or so. will work fine.
Old Apr 11, 2008 | 09:30 PM
tjbmxrider's Avatar
Default RE: help
thanks!
Old Apr 11, 2008 | 11:01 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: help
the thickness of your speaker wire only needs to be equal to the thickness of the tinsel leads. anything larger is unnecessary overkill.
Old Apr 12, 2008 | 01:40 PM
tjbmxrider's Avatar
Default RE: help
what is a tinsel lead?
Old Apr 12, 2008 | 01:49 PM
bobditts's Avatar
Default RE: help
the wire that connects your voice coil to your connector on the sub itself.
