Hid's
Old Jun 13, 2009 | 11:26 AM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default Hid's
Just wondering if anyone had a how to on the direct connect relay harness for an hid kit? i think i did it right but i want to make sure. everything was from hidextra.com
Old Jun 13, 2009 | 01:20 PM
Looks like it has a ground wire that should be attached to a good chassis ground (black), +12V wire to the battery (red), a plug to the existing headlight plug, then two plugs out to the HID balasts.
Old Jun 13, 2009 | 09:45 PM
Numba1Sean's Avatar
yea i guess i did it right. i did everything direct to battery though. having a prob with the passenger side one not lighting up properly. as far as the drivers one kicks on but the passenger one doesnt all the time. i have to turn it off and turn it back on several times before the passenger one comes on. would slight corrosion cause this? if so i will have to look at all plugs on passenger side.
Old Jun 14, 2009 | 09:19 AM
If you are powering them off the same source (via the relay kit), then they should come on at the same time. If they do not, then there may be a wiring problem inside the harness from the relay to the passenger side light or the balast may be faulty.
Does the passenger side light work properly when direct connected to the vehicle wiring?
Old Jun 14, 2009 | 10:43 PM
Numba1Sean's Avatar
yea off the relay kit. i havent tryed direct connect due to my nervousness of melting things. u can hear it try to ignite but the light dont come on and then sometimes they will both come on no problem.
Old Jun 16, 2009 | 03:13 PM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
ive had that happen, its either a bad ballast or the bulb is bad, i bought 2 spare ballasts and a spare bulb from the seller i got mine from just incase, i used the ballast right away and it fixed it. try swapping the ballst from the good side to the bad side and see if it ignites everytime
Old Jun 24, 2009 | 10:17 PM
Numba1Sean's Avatar
updated: well everything was working perfectly for 1 straight week. then stragedy again this time drivers side wont work. with the aid of someone hitting the light switch the ballast makes the igniting noise. then i held the bulb by the plastic piece and the bulb does a quick flash then turns right off. should i switch out the bulbs from each side to see if the bulb is indeed bad or does it sound like a ballast? i flicked the switch so many times that the passenger one wouldnt work either till i let everything cool down.
Old Jun 30, 2009 | 09:18 PM
Numba1Sean's Avatar
ok has anyone else had a problem with the hid kit from HIDextra.com?
Old Jul 1, 2009 | 01:44 PM
PVT Pablo's Avatar
PVT Pablo is an unknown quantity at this point
With this kind of stuff, cheaper is not better. It seems to me, regardless of install, the more expensive HID kits (150+) have less problems. I bought mine about a year ago and paid close to 175 and have not had a single problem. Two of my friends bought the same system I have and also have had no problems. My other friend however, bought some crap off of ebay and sure enough, 3 days later, he had a dead ballast.
The prices have come down considerably, but if you want a good set of HID's from an awesome company, go to IntenseHID.com I had a ton of questions before and after the install and they always made me feel confident in their product.
God I sound like a walking ad lol.
Old Jul 3, 2009 | 11:36 AM
tprouty's Avatar
tprouty is an unknown quantity at this point
I was having the same issue and mine was that the vehicles harness is bad and I had to zip-tie the connectors together and it works fine. Mine would go off with every bump and everything. Try moving the vehicles wiring that goes into the headlight plug.
LuvMyTJ
Apr 22, 2010 09:59 PM
drperry
Jan 13, 2007 07:27 PM
kaindragoon36
Dec 1, 2006 08:01 AM
jagblazer01
Mar 9, 2006 10:43 PM
blue_green_rider
Feb 7, 2006 10:44 AM
