I Hate Wiring my Own Decks/Amps
Old Nov 16, 2005 | 09:10 PM
FarkDaNarc's Avatar
FarkDaNarc is an unknown quantity at this point
Default I Hate Wiring my Own Decks/Amps
so i put in my new soud
this is the deck
http://www.bestbuy.ca/catalog/prodde...8&catid=21981#
this is the amp:
http://www.bestbuy.ca/catalog/prodde...21&catid=20103
and so i get it all wired up and.....wtf...my sub doesnt pound......god damn, forgot to run a Remote wire. shoot me please. i find this out AFTER i put it all back together. i was in a rush. sux 2 be me. im also a bit of a retard when it comes to doing this. anyone got any tips for what to look for, or make sure i do before i put it all back together again, to find out its all bunked again?
Old Nov 29, 2005 | 03:04 AM
Audissey's Avatar
Audissey is an unknown quantity at this point
Default RE: I Hate Wiring my Own Decks/Amps
well, just make sure errything is hooked up. remote is like a power switch for your amp. basically, when your deck turns on, your amp turns on. you could run it through a toggle switch. that way, you can turn off your amps. hope i helped! holla!
Old Dec 4, 2005 | 01:33 AM
2000ZR2's Avatar
2000ZR2 is an unknown quantity at this point
start it up and make sure everything is runing and nothing is phasing out( when you hook the POS and NEG) up back words the woofer will go in instead of out and make sure the amount of ohms u r runing is correct to avoid amp damage
Old Dec 4, 2005 | 10:10 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
make sure everything is connected securely and to the correct place. check inline fuse and fuses on amp. make sure you have a good ground (test metal with a digital multimeter, then sand away dirt/paint, and bolt ground wire on tight). if all else fails, trash that crappy sony amp.
Menace
Apr 27, 2011 07:07 AM
PFCBarner
Oct 19, 2009 08:13 PM
rooster
Dec 6, 2006 02:59 AM
Bojib
Jul 4, 2006 06:24 PM
Bojib
Jun 25, 2006 10:53 PM
