Installing a Sub
Old Jul 21, 2012 | 08:32 PM
martins blazer's Avatar
martins blazer is on a distinguished road
Default Installing a Sub
I have an 11" sub that I'd like to install in my blazer (97). It requires a power cord that has to be run along th right hand side. Whats is the best way to do this?
Old Jul 21, 2012 | 08:50 PM
chris015's Avatar
just remove the foot panels along the bottoms of the door and run it through there under the dash into the engine bay..
"power cord" I hope you mean actual sub wire like 4 gauge and not a drop cord. it'll burn up if you dont do this right.
Old Jul 21, 2012 | 09:37 PM
247monster's Avatar
i ran my power power wire on the passenger side (the whole left right thing can be confusing lol) as a tip find where your anttenna wire goes into the firewall and follow that its right there and an 11" sub?...thats...an odd size...lol or did you just mistype
Old Jul 23, 2012 | 03:50 PM
whyteb0y's Avatar
whyteb0y is on a distinguished road
Make sure you run your power and remote wire on one side and the RCA cables on the opposite side, this will avoid any unwanted alternator, or any other weird noises.
Old Jul 26, 2012 | 05:58 PM
bluedevil500's Avatar
bluedevil500 is on a distinguished road
Make sure you check out some basic stereo DIY's. You will need a power cable, negative cable, remote cable, and then RCA's. The placement of the connections for the power/ground cables are equally important, as are the thicknesses of them.
Old Jul 26, 2012 | 09:45 PM
jagblazer01's Avatar
an 11" sub?? where did you find an 11" sub?
Old Aug 3, 2012 | 12:11 PM
Elemental designs has some "technically" 11" subs. They are really 10" subs, but I believe because the cone itself is like 10.5 or something, they just round it up.
Old Aug 4, 2012 | 04:06 AM
99lsdriven's Avatar
99lsdriven is on a distinguished road
It probably is a 12 with a larger-than-normal surround. JL did something similar with their w7 13" sub.
Kresh
Feb 13, 2010 04:13 PM
Canadian88
Feb 23, 2006 12:55 AM
1BlazR
Jan 20, 2006 10:00 AM
Freekstile
Aug 19, 2005 04:40 PM
Deadeye
Aug 13, 2005 08:40 PM
