Issues
Old Aug 28, 2008 | 11:15 AM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Issues
How do i get the dash piece off to get to the radio?! i took the bolt above the gauges out and the 2 under the steering wheel. i assume after that it should just pop right off but its getting stuck on stuff. i thought i was going to be easy.
Old Aug 28, 2008 | 12:36 PM
jagblazer01's Avatar
Default RE: Issues
you gotta take the bolts off on the panel under the steering wheel and drop that down...there is a bolt on the bezel on each side of the steering column. take those off and everything else will just pop off....make sure you disconnect any switches that are attached to bezel (multi-purpose switch, 4x4, rear glass, etc.)
Old Aug 28, 2008 | 03:00 PM
Default RE: Issues
lol i found the 2 behind the panel, finally got it off but i dont want to pull to hard on the connections in the back.
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
