JVC KD-G230 need help
Old Dec 25, 2007 | 08:43 PM
95_Blazer's Avatar
95_Blazer is an unknown quantity at this point
Default JVC KD-G230 need help
So i hooked this bad boy up to my car, and everytime i shut off my blazer my settings get reset as if it was just taken out of the box, any help please.
Old Dec 25, 2007 | 08:46 PM
TripleBlackBlazer's Avatar
Default RE: JVC KD-G230 need help
Check your constant wire, I believe it's yellow. If that's not properly connected it will lose power everytime you shut the key off and therefore resetting your settings. How did you wire it up? Wiring harness from factory to new HU? What connectors did you use?
Old Dec 25, 2007 | 08:50 PM
95_Blazer's Avatar
I used the harness from my old unit, but the yellow wire broke off, so my dad used a connector to hook that up i may pick up a new wire harness.
Old Dec 25, 2007 | 08:53 PM
hillbillyinOhio's Avatar
if you did not use a harness (metra part number 70-1858, you wired up the 12v constant wrong. The 12v constant in the dash is orange, and the switched is yellow. YOu would wire the orange in the dash to the Yellow on the radio. and the yellow in the dash to the red on the radio.
Old Dec 25, 2007 | 09:09 PM
95_Blazer's Avatar
We hooked the yellow up to the yellow, i figured color to color, hopefully just getting a new connector will work.
Old Dec 25, 2007 | 09:22 PM
So, you did get the harness??? check the pins.
Old Dec 26, 2007 | 08:12 PM
95_Blazer's Avatar
Yea i had an old harness, i just bought a new one today and will put it in when i get my car back from the shop, i may need a 4 wheel modular.
Phil
Mar 3, 2010 09:53 AM
loomdog32
Nov 21, 2009 01:08 AM
zackbennett
Jun 28, 2008 10:55 PM
drefda
Feb 23, 2007 10:44 AM
