Kicker vs. Fosgate
Old Nov 16, 2006 | 03:20 AM
  #41
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default RE: Kicker vs. Fosgate
not to be a thread *****, but how do you tune your boxes to a specific hz?
Old Nov 16, 2006 | 03:22 AM
  #42
man, to get a good, cheap wiring kit, go to www.sonicelectronix.com they have lots of rf and kicker stuff on there. i'm running a stinger 2guage right now, which is overkill. if i were you, i'd go with an 8guage ground and power. that should be right on the money.
Old Nov 16, 2006 | 03:23 AM
  #43
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Make another post for that bro.
Here's the basic wiring
If ya need help with that let me know I'll break it down as a step by step.
And no need to thank us. It's what we're here for.
Old Nov 16, 2006 | 03:24 AM
  #44
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
k... thats much easier... so I connect both positives to the same terminal and both negatives to the same terminal...... so I bridge them both on the same terminals? like I was bridging one sub on 2 channels? the amp shows wich positive and negative to use to bridge...
Old Nov 16, 2006 | 03:27 AM
  #45
exactly. welcome to the great world of subwoofers.
Old Nov 16, 2006 | 03:34 AM
  #46
XBlazer01's Avatar
First we run 1 power line from the + on the amplifier to the + on the first sub.
Next we run 1 more power line from the + on the amplifier to the other + on the second sub
Now time to run a line from the - on the amp to the - on the first sub
Now we do the same thing for the second sub
And we connect the - and the + on the first sub. Thusly raising the ohm load on this voice coil
And do the same thing on the second sub to achieve 2 ohm's
Old Nov 16, 2006 | 03:40 AM
  #47
a_tack's Avatar
I always thought running a wire between the + and - on the speaker would short something out.... if the subs are 2 ohm subs I still have to do that? so i would basically have 3 wires on each sub...
one from + on sub to + on amp
one from - on sub to - on amp
one from + on sub to - on sub?
on both subs?
just making sure I understand this correctly
Old Nov 16, 2006 | 03:42 AM
  #48
yep. 3 wires.
Old Nov 16, 2006 | 03:44 AM
  #49
XBlazer01's Avatar
Nah doing it like that wont short something out. Cause in the first place theres no signal going through them basically.
And like he said yes 3 wires
  #50
a_tack's Avatar
k... so ill order 2 2ohm Kicker CVR's and wire them like the diagram... this will give me the deisired results?
