Legacy of Boomtruck: The Build!
Old Oct 30, 2006 | 01:27 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
Default RE: Legacy of Boomtruck: The Build!
Another update being made!!!!!!
new amps to be used!
Lanzar Optudrive 2000D amps - 4 of them. running 4 12's to each for 500rms/1000 max wired at .5 ohm
New speaker setup!
redesigned a tad after State MECA finals yesterday - not using 12 12's anymore.
i had changed it to 12 15's for a minute, now its
16 12" Sidewinders!
hehe, lets see how much crazier i get before this is totally done.
Old Oct 30, 2006 | 03:20 PM
jagblazer01's Avatar
hahaha dude you will def. change ur mind like 100 more times before all is said and done[8D]
Old Oct 30, 2006 | 04:07 PM
but at least you can feel safe knowing that it will only keep growing. and besides - i start the boxes construction in about a month or so. the dash is underway. i am running out of time to change things to much more.
Old Oct 31, 2006 | 11:49 PM
blazinloud's Avatar
U......R.......MAD
and you must be loaded.....dont ur pants fall down with that much cash in there?
Old Nov 1, 2006 | 01:29 AM
u gonna post progress pics dude?
Old Nov 1, 2006 | 10:09 AM
i was going to, but i got some bad/good news last night - the setup is changing majorly! more power to less speakers. basically its changing to 4 of the 15 inch Napalms and a 3000rms DS-class amp to each on. the box is going to be a fiberglass wall. it will be amazing but insane non the less.
and im not loaded, that much at least - this is a multi month build and i have about 3 sponsors for the project now.
Old Nov 2, 2006 | 10:21 AM
blazinloud's Avatar
so you went from 16 all the way down to 4......and whats the diff between a class d and a ds?
Old Nov 2, 2006 | 11:21 AM
there are a few things to realize when i say that however. for one thing - the difference is that i was going with 16 12" subs that would be pushed hard by 500rms, and thats what they would have been getting. not im moving to 4 15" subs that will be getting 4000 rms each. that actually means the truck will be using twice the power as before and a quarter the number of speakers.
Another point is that instead of a mostly wood box, it will now be a fiberglass box - fiberglass doesnt obsorb sound as much as wood does. plus i will have more room for batteries and such this way.
Its not the number of speakers that determine the loudness - its the quality of product and how its used.
there is a comp car now that uses 4 of the 12" Napalms (im going to use the 15" Napalms) and it has one 4000D amp (vs. the 4 i will be using) and it does a drive by on a MECA mic at 133 in an enclosed wood box. im confident when im done to be in the low to mid 160's. at minimum - high 150's.
amp classes - if i recall digital circuit and d-class are the same, but it means that the amp is more efficient but only available for low frequency uses. check with Pat or Jon to make sure though.
Blaze1Chef
Mar 7, 2021 10:44 AM
moose4553478
Lifting Tech
Oct 24, 2009 12:41 AM
bowanna03
Aug 10, 2006 09:58 AM
PawNtheSandman
Engine & Internal
Jun 28, 2006 02:48 PM
