License Plate Lights out
Old Mar 3, 2007 | 08:57 PM
Clock72's Avatar
Clock72 is an unknown quantity at this point
Default License Plate Lights out
I am new to the forum and this is my first post. 2002 Blazer LS. Both license plate lights are out. I changed the bulbs with brand new ones with no luck. I am wondering if there is a fuse for these lights. Also, if I have a wiring problem, what other parts should I expect won't work. Everything else seems to be working and I am very happy with this purchase.
Old Mar 3, 2007 | 11:21 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: License Plate Lights out
It will be a 10a fuse in the under hood fuse box, labeled TRL PRK. If you have towed a trailer lately, and the fuse does not blow when you replace it, I would check the trailer that you used. If you have not towed a trailer, I would check the trailer wiring under the LR or the truck, to make sure none of that is shorting out. Good luck, Korey.
Old Mar 4, 2007 | 05:50 PM
KOYOTE's Avatar
KOYOTE is an unknown quantity at this point
Check wireing from plate lights to tail lights
Philipx
Dec 14, 2015 04:29 PM
Viperguy
Sep 29, 2009 12:27 AM
pbd3mon
Dec 29, 2007 08:24 PM
Jhop16
Oct 9, 2006 09:10 PM
16gauge
Oct 17, 2005 12:01 AM
