Line drivers...
Old Jul 10, 2008 | 09:19 PM
Big Frost's Avatar
Big Frost is an unknown quantity at this point
Default Line drivers...
Worth the money?
do they really make a big difference?
Old Jul 10, 2008 | 10:49 PM
The A Team's Avatar
The A Team is an unknown quantity at this point
Default RE: Line drivers...
Daily driving probably not worth it in the grand scheme of things.... but you will get a cleaner signal and a balanced output.
I know in all my SPL builds a line driver is a must to fine tune!
Old Jul 11, 2008 | 01:03 PM
Big Frost's Avatar
well are there advantages from using a line driver versus the amps gain?
Old Jul 11, 2008 | 08:18 PM
blazinloud's Avatar
the amps gain is to match voltages with your deck
Old Jul 26, 2008 | 05:36 PM
20injimmy's Avatar
20injimmy is an unknown quantity at this point
a line driver will put out a stronger and cleaner signal witch it will make any amp run more efficant. so thislets the amp produce more power with out the amp straining to pull more power to achevie its rated power. this also helps with low imp loads stains on a amp@ 1 ohm or low. over all a line driver is good in not just in spl but any application. when it comes to the meter u will see a diff with the line driver over with out one, by ear u wont know.
Impact
Apr 17, 2015 09:54 PM
Xavier
Apr 11, 2014 11:49 AM
scphill34
May 30, 2013 10:20 PM
Nathan1991
Nov 4, 2009 10:34 AM
jf_stan
Aug 15, 2005 12:43 AM
