radiator leak, drivers side, either hose nozzle or insulated line coming out
Old May 30, 2013 | 04:28 PM
scphill34's Avatar
scphill34 is on a distinguished road
Default radiator leak, drivers side, either hose nozzle or insulated line coming out
1995 blaze, 2dr, auto, 4wd. At the top of the radiator drivers side. It appears to be one or both of those connections, I don't know if that is a ac line but it is bolted on to the hosing and insulated. Drips out pretty constant under pressure. Only other place it could be would be the crimp around the plastic tank. I have coolant residue there as well. Is there a seal in that area that might need replaced? Any suggestions ?
Thanks
Steve
Old May 30, 2013 | 06:14 PM
richphotos's Avatar
those are the oil cooler lines, you can try removing it, and putting some plumbers tape on it
Old May 30, 2013 | 06:43 PM
scphill34's Avatar
I determined the source it is the top of the radiator and about 1-2 inches down from the top where the metal crimp is it is hissing out of the crimp when pressure builds can that be repaired or does it have to be replaced ? If is there a seal that needs replaced as well.
Old May 30, 2013 | 07:12 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Radiator shop,or replace it. I chose to replace mine.
Old May 30, 2013 | 07:17 PM
cleburne red's Avatar
Mine was leaking at pretty much the same place. Driver side, right on top where the side tank is crimped onto the core. I thought about a radiator shop, and I might still, since I still have the old one. But I just ended up replacing it.
Old May 30, 2013 | 09:50 PM
scphill34's Avatar
What did the replacement cost
Old May 30, 2013 | 10:00 PM
It was around $100 at rockauto.com. Autozone wanted like $160, I think.
Old May 30, 2013 | 10:20 PM
richphotos's Avatar
its like 100 for a rad, real easy to replace. you honestly can do it on your own.
Bolbol
25
Apr 15, 2015 09:41 PM
Fast Rider
Dec 22, 2014 08:44 AM
RCarp48
Sep 11, 2012 01:21 PM
Wexinlo
Apr 6, 2011 11:35 PM
rob1621
Apr 3, 2008 08:55 PM
